WebMaximus
Hey guys, need your input and advice.
I have a Corsair Obsidian 500D SE case where I'm currently using a Corsair H115i RGB Platinum AIO mounted in the top of the case as an exhaust. In the front, I have 3x120 fans as intake and in the back of the case, I have another 120mm fan as exhaust.
My CPU is an 8086K and my GPU is the MSI GeForce RTX 3090 SUPRIM X.
Now I'm thinking of replacing my 8086K with the 12900KS. I spend most of my time in MSFS in VR and have found my CPU to be limiting me. I understand the 12900K series of CPU:s and the KS model in particular I guess will get very hot. Why it's important to have good cooling in place.
Since I won't be able to use my current AIO with the new socket and CPU, I bought these two and now I'm trying to figure out which one to use and which one to return.
https://www.webhallen.com/se/product/341676-Corsair-iCUE-H150i-Elite-LCD
https://www.webhallen.com/se/product/348815-Corsair-iCUE-H115i-RGB-Elite-280mm
If you compare the 280 vs the 360 side by side, I assume the 360 will provide better cooling performance. Simply due to it's larger size and for moving more air. However, since I already have a 280 mounted in my case, it would be easier to switch to a new 280 rather than a 360.
Also, since I guess I would need to mount the 360 in the front rather than in the top of the case and with hot air moving upwards, maybe the advantage a 360 has over a 280 wouldn't be that huge based on the different location in the case. Maybe it would even perform worse...
I've tried to find out if it's possible to mount the 360 in the top but most people seem to say 'Not possible'. While a few claimed they managed to do this. So I'm not really sure.
Obviously, the best thing is to give it a try but before I start unboxing stuff over here, I figured I would ask in here.
Many thanks in advance for your help input guys!
