My Gold --- update: Light effects
Dye colour option for the loops.
  • Total voters
    28
Cool, can't wait to see the tubing when it gets completed.
When you use the screws, won't the paint chip off at the threads?
Im not painting the thread on all of them. If they get alite paint on its very thin and just for the looks. The only screwes im painting the thread on is the acrylic/140mmfans/filter screwes. But only 3-4mm of the end thread is used with a nut. The rest goes trough the acrylic, fan and filter(invicible almost)).
Fanscrewes with antivibration on:
Bought a soldering station today:
Dont know how mutch i will get done the two days i have off now. When i woke up today i was fealing a bit sick with slightly fever, headache and muscle ache. Il rest some and hopefully it goes away
Recieved some goodies tonight. Both waterblocks and some wc T-adapters, some leds, 3pinn housings and modmytoys led station.
*drools* Can't wait to see them on the cards
Gonna have to take a few photos of my modded cards first before i slapp on the blocks :-)
After all i did spend many hours painting the shrouds properly.
Beautiful !!! watching this topic. you've put some damn good work into this.
Thanks.
I couldnt wait any longer for my set up to be done so i have started deauz ex. The game runs fantastic on full settings with 5870 and the hackings and combate system is just supercool.
Back to some seriously deuz-x gaming :-)
Heres a few more shots of the things. Ive already orderde alot of moren things to re-do a hole psu + paracord but that will be updated later.
This will be replaced by a larger led station from Bitspower.... :-)
Swoping any white housing with these nice black ones.
Some pre wired leds, though i will be making my own thankfulyy. Alot more fun and learningfull, amen....
Needed one more T-Adapter just in case i would desperatly need one more :-)
Love having my afterwork coffe and read all the buildlog updates, for some reason I always end up checking yours first =P Can't wait to see the loop come to life!
A litle update. Decided to start flushing my rads this morning so my first rad is running with fresh cold water right now. Running them with hot water for 20min and then cold water for 1-2h. Got some destilled water also witch im boiling and run trough one time. There was this really industrial smell when i ran the first one with hot water, so i guess its good to flush them. Didnt notice any metal/dust coming out, but i guess there are particles coming out of it, and if i used a big fine filter we could see these particles.
The weather out is to bad for sanding and its been like that for the last week. Hope it can be a few days with no rain so i can sand the housing on the inside. Bought more white paint for the outside and 1l of black for the inside.
The weather in the U.K has been fantastic so far this week. Hopefully you get some awesome weather in the near future so you can start the painting process again. Looking forward to seeing the painted insides and completed exterior
Yeah hope so too. My gf and kid travells to the familys cabbin this weekend so i should get some days where i can sand and paint. Will be good progress then because i can leave everything out when they are away
Edit: I started to paint the lian li thumb screwes for the motherboard.
Now that I am on my own the amount of tools, steel and random crap left all over the place is insane
Nice to know its not just me wanting to leave this stuff everywhere
Wish i had a big garage or a big workroom :-). Draging the tools out/back and cleaning the room after takes a large ammount of time..
Pretty jelly of your internet speeds TBH
Yeah its nice :-)
*New* ordered one more Vertex 3 120gb so i can put them both in Raid0. I see many stores are now getting the Z77 MB's in stock. Will order the UD5 asap when one of my fav webstores gets it in sale. A few weeks with good progress and i think the housing will be ready. From what ive heard the 3770k will be launched in the end of April, so its good to have everything ready by then.
'New* Today i have ordered the GIGABYTE GA-Z77X-UD5H Z77, OCZ Vertex 3 120gb and mass effect 3 game
Ive just finnished my third nightshift and i now have 3 days off, Will finnish off the sanding/painting of the housing, the hidden lightning and i also plan to paint the rest of the new fans i bought. Ive painted alot of screwes but i need to paint the heads on all the rad screwes also. Will make the last cut outs around the MB tray right now.
Ive been given the tray and hdd racks several coats of clear paint. Painted bolts/nuts for the acrylic in front, gold painted MB thumb screwes and some painted large cable clamps im planing to use for the tubing.
Will probably be back with more tonight.
Everything is looking amazing as ever!
Thanks m8.
I finnished the cut outs around the MB. Still need a litle more sanding in the holes but il do that tomorrow. Also glued on the stand offs for the tray.
Will try and start painting some fans tonight. Im gonna be so relieved when im done sanding :-)
