ciobanulx
interesting pattern choice. Car manufacturers usually use this pattern on new prototypes and models in order to hide shapes and contours
I love this frame though. Trying to find one in Norway to order it.
I didn't know that hehe
I actually wanted to do a triangle pattern as I can see there are triangle patterns all around the case and I based this on the triangle cut outs IN WIN made on the sides of the HDD mounts.
I sorta just based it from there and then I found a seamless triangle patterns that I just used to cut the vinyl and create this design
No green![]()
Yea I'm keeping the green minimum. It will only be from the case itself as well as some green accents on the custom cables and the GeForce logo on the GPUs
