Surfie
Hi folks.
Those who have read the Frankenstein project log, will know what the go here is.
For those that have not, this is a minor update to Blue Marble, whereby i dismantle the entire rig, paint it white inside and out (possibly with a textured finish outside, I'm not 100% sure on that yet), update the graphics card, turn it so that it is vertical, paint the fans, and manufacture a better psu shroud. There are a couple of changes to the loop too. Bonus points to those that spot them.
So, the first thing to do is to go over what Blue Marble ended up with.
Hardware:
ASUS Rampage IV Formula
Pentium 3930k i7
32 gigs RAM (heat spreaders removed for the beast) corsair vengeance
Corsair RM 750W PSU
2x Samsung 256gb SSD
1x western digital 2tb mechanical drive
1x Samsung 1tb SSD drive
Fractal Define S Watercooling
Inno3d GTX 1080Ti TwinX2 (NEW)
Watercooling:
XSPC Raystorm CPU block (recycled)
XSPC GTX1080TI GPU Block and Backplate (NEW!)
Singularity Computers Protium Medium Res and Mounting system (NEW!)
Alphacool UT60 360mm Radiator (recycled)
Alphcool UT60 240mm Radiator (recycled)
EKWB Black Nickel Hard tubing fittings (12/16mm) (Some new, some recycled)
EKWB PETG 12/16mm Tubing (2 meters worth - hope it's enough!)
XSPC 90 & 45 degree fittings (recycled)
5x Corsair 120SP Fans (recycled - old style: NON LED)
Please be aware, this project is in progress, and happening (more or less) now.
The work done so far (No pictures taken at this point):
Dismantled the water cooling loop in its entirety (Golly that took an AGE!).
Uninstalled all cables, and hardware from the case.
Stripped the panels previously covered in vinyl so that they are back to factory.
Stripped the case back to its base shell. This will have its rivets drilled out tomorrow morning.
Opened up the XSPC block, and removed the faceplate. My intention is to paint it, but i'm unsure about whether to go white or blue - anyone got any ideas?
Next steps:
Drill out the case rivets.
Apply the necessary mod to allow the GPU to be mounted vertically.
Wash all the panels which are being painted down and prep for painting.
Paint and possibly apply special effect.
Hardware:
Pentium 3930k i7
Corsair RM 750W PSU
Watercooling:
Next steps:
