My Gold --- update: Light effects
Dye colour option for the loops.
  • Total voters
    28
Good to see the weather is on your side, making really good progress lately, can't wait to see it fully painted
Paint looks really smooth, really nice
Cheers. Ive sanded the first coat lightly and added second one now. Looks better now and even smoother. Had to use more levelling compound on one of the shortsides.The joint had a very minor crack line and i also found a branch with minor hole in it. Its so easy to see these things when primer i added
Im using a half glossy water based paint after the primer. Exited about how it will look
Heres backside now after second primer coat:
Above psu cut there is a branch hole. Think it must have fallen out during sanding. Will fix that tonight/tomorrow
Edit. Fixed the branchhole, backside been sanded and primerpainted for the third time. The shortside has also been sanded and painted again.
When you've got it on your dining table, you actually start to get an idea of the scale of the thing. Looks Fantastic dude.
Looking good, I keep getting excited about seeing the updates lol
Thats nice. Im getting more and more exited too
Thanks Sheroo. The measurments of the housing is H21,8cm L153cm, D59,3cm in depht so its pretty close to the lenght of a normal office desk. When its placed on top of the cabinets the hight is same as the desks ive already got in our apartment.
Admirable handwork during this build! Cant wait fore updates!
Cheers dude. Glad you like it
Right now im continuing working on the fronstide. Ive sanded it after first coat and i am now waiting for some levelling compound to dry, and then sanding it down again. Im gonna show you how it looks like after third primer coat. Im at work the next 4 days so im not sure how mutch progress there will be, but il keep updating if i get something done.
One more package arrived from
4x pcie 6pinns
2x pcie 8pinn
24 and 8pin
5x molex extensions
Im pretty exhausted today but il try and get some painting done tonight. Got 3x nightshifts coming up
Thanks. Ive decided to sell those uv blue extensions i had from earlyer and replace them with the bitfenix ones with a nicer darker blue colour. Ive also got my new modem tonight, see speedtest link
Jesus! I would kill to have internet like that. My download is half your upload speed man, haha!
Wow, you're Internet is awesome. I'll hopefully have 60Mb/s sometime this year.
I wish we had that kind of overall quality in internet services here.
Was an easy decision to upgrade. Only 5£ more a month from 25/5 to 70/10
Still strugling with the new router i bought earlyer. Gonna run some sofware to capture LAN packets and WAN packets when i visit the pages im having issues with. It will most likely be returned to seller as i cant be bothered with this buggy thing.
1 more nighshift left and im back to working on the project
