MW3 for £26.65
BTW guys I said earlier to remove the Russian files when you put the English ones in "don't do it, leave them where they are or steam will keep downloading them!!!!"
I just read it somewhere whilst trying to find faster links to the English files and realized that is what Steam has been downloading all day killing my bandwidth
I used the first method and i've just checked my IP address and it's gone back to my normal one so I think it stops after a while and that it's just a demo version.
Oh and you can stop it as soon as you have activated the key.
Are you using the solution 1 way? I just chose Ukraine from the list and it worked strait away.
I used Solution 1 afterwards. It didn't open for me firstly; it came up with Adobe Pixel Bender, which uses the same file extension.
I did a little reg edit and it worked INSTANTLY.
If you are having the same issue on Windows 7 take these steps:
1. Launch Notepad.
2. Copy the following content into Notepad.
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\.pbk]
@="pbkfile"
3. Save to Desktop with the name .pkb.reg.
4. Launch the saved file from Desktop to modify the registry to change the file association.
Good news... it downloaded an English version! I didn't have to change any files.. sooo strange.
Edit: ALSO.. if anyone is having issues with the first Russian VPN trick, use Solution 2 with this code: 671902
I e-mailed them asking for one, and they oblidged.
So the one steam downloaded was in English? I hope it's the same for me!!!
You got lucky Bloomerz
I read some of the reviews on the site earlier and it looks like a few other people got an English download as well.
I'm going to check when I get home whether I got an English copy aswell, fingers crossed!
Yep, i got the enghlish copy aswell, just had to ad the localization file and that was it...
Thanks you SieB for this your a star!!!!
It's a digital download and it works alongside Steam.
Get it here: http://uk.gamesplanet.com/buy-download-pc-games/Call-of-Duty(R):-Modern-Warfare(R)-3-2660-38.html
And in the checkout, enter in the promotional code: MW3
Tried to purchase just now, code is either expired or invalid
. No way am I paying £40 for an expansion.
Awwh man, It must have been for one day or something.
Sorry to hear that. Definitely try SeiB's way though, cheaper option also.
