I hope this all works out for you, Ive seen some horror stories with these panels in the past!
Thanks, yes I have spoken in depth with the guys at ELW&T, most common problem with the tapes are burning them out, this is because the power is to high for the amount of tape or bad connections.
I've been playing with the tape for about a month and feel confident it will all go to plan
The EL wire as Alien below has just mentioned, has been around for some time now and
I know that should be perfect
EL wire. Haha I used that in my first mod in 2003it was all the rage then.
Yeah, I was using it around the same time also
It's effective but sometimes tricky to stick in place without making the groves.
I think once im done with this build, any left over EL bits will be used to make my trainers glow lol
