wassupdoc
*update*
Update time
So I got the first stage of the build almost finished at the weekend (in the short time I had while my girlfriend was out
). The PP-18 is almost ready to be fired up
I'm really happy with how the wiring turned out!
First power on
(no valves) ANNNNNNNN Success! All the internal voltages match up on this particular test
Time for the valves!
PROBLEM :dammit:
I finally got around to making the measurements for the PP-18 with the valves installed, turns out my mains voltage is over the legal limit
I'm reading 256V AC so it's affecting my internal readings quite a lot! It's going to take me awhile to work out the new desired internal voltages I should be getting... :banghead:
Barry from Ampmaker said I may have to tame it with something called a zener diode??
Also forgot to say I received a rather lovely electric shock while measuring the valve-in internal voltages! But ah well :bornleetsign: Can't say it didn't scare me (or fooking hurt!) but I've got some lovely burnt pinhole entry and exit wounds! (which i used to work out that i must of caught my arm on the chassis - accidentally grounding myself :banghead: - and exiting through my knee to the floor
Update time
First power on
PROBLEM :dammit:
