I was determined to get the 180mm rad in there but at the same time utilize 2 Silverstone 180mmAir Penetrator fans in a push pull config, however they fouled the mobo by about 3mm so i took the top 180mm fan and literaly shaved 3.5mm off the bottom of it, this means it just fits in but at the same time the fan does not foul the rad in any way, of course i also had to cut out some of the mobo tray just like Tom did in his video.
Ive got all the wiring and tubing to do next, oh and also notice how ive fitted the Pump res combo by using a 150mm L shaped bracket bolted to the rear of the case under the PSU, this was because i didnt want to be running tubes all the way to the front of my case and it being an FT02 theres no floor space available so i had to get inventive, i do hope it turns out alright looks wise but hey ho time will tell.
The latest of my FX8350 build photos, CPU is installed, Watercooling is leak tested, Windows 7 is installed on SSD drive, doing all updates at the moment.
