The_Governour
Here I am yet again with the Lian Li Q10 and this time I wanted to place a fully Custom Loop in its megarly 19L. What I was looking for was a case with a side window and at least 1 space for a 120mm radiator. With this then I wanted to cool both CPU and GPU with a lonely 120mm radiator. I also wanted to keep ALL stock as of components as I wanted to do this so all can do a build like this - there a re many modders out there that can do wonders but here I want everything out of the box.
I understand that the minimum would be 120mm of rad space per component but I wanted the smallest possible scenario while yet keeping the sleek looks.
The components are the following:
CPU: i3 4130T
MOBO: z97 i - plus
GPU: Asus GTX 960 Mini
SSD1: Windows Samsung 840 EVO 120 gb
SSD2: *Por Confirmar*
WC Possible parts:
Different possible 120mm radiators: Or Alphacool with 30mm Or Ek with 45mm Or Fractal with 45mm
Pumps: Either the pump of the Fractal T12 Or the Eisberg Pump Solo, the low rpm version.
GPU Block: Custom block from AlphaCool for the ASUS GTX 960 Mini
VFans: *Depends* if I have to use SLIM o normal ones.
Fittings: EK-HDC Fitting 12mm G1/4
Tube: EK-HD PETG Tube 10/12mm
CPU: i3 4130T
MOBO: z97 i - plus
WC Possible parts:
Alphacool St30:
Ek XT 120:
Fractal T12:
Alphacool Eisberg:
Custom block - Asus GTX 960 Mini WITH backplate:
As you can see then I have a 960 in the mix - and WHY would you water cool that?? The first of its kind as it was made specialy for my request and Alphacool was nice enough to do it. The reason why, just because I wanted to - and to have a watercooled PC all cooled by a single 120mm radiator.
I have most of the components here, now just to wait for the time to start....!
*EDIT* The reason why I had the 1150 components for this and the 960 was due to the fact that I started this project a long tima ago but I did not have the time to do it due to children etc etc. I would like to re do it but with more up to date harware - later on.
