Help with some coding
KING_OF_SAND
So in my computer science class we are asked to do some very simplistic C# coding. All i am required to do is have a child implement his first and last name, parents full name, and phone number. Then i go to debug mode to see if it all works, and it does "to a point." after i implement the phone number and press <Enter> again it is supposed to display all that was entered one last time. and it does but only for a split second after pressing <Enter> when it is supposed to stay up so it can be viewed. can someone explain to me why it is not.
Here is the Code:
Program:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using NameProject;
namespace NameProgram
class Program
static void Main(string[] args)
showMessage sM = new showMessage();
ShowMessage
using System;
using System.Linq;
using System.Text;
namespace NameProject
class showMessage
public showMessage()
String F;
String L;
String P;
String phoneNumber;
Console.WriteLine("Please Enter Child's first Name: ");
F = Console.ReadLine();
Console.WriteLine("Please Enter Child's last Name: ");
L = Console.ReadLine();
Console.WriteLine("Please Enter Parent's first & last Name: ");
P = Console.ReadLine();
Console.WriteLine("Please Enter Phone Number: ");
phoneNumber = Console.ReadLine();
Console.WriteLine("Child's first Name" + F + "Child's last Name"
+ L + "Parent's Name" + P);
very simple but it works, again to an extent.
also forgive that the indenting is not correct, its the forum that is screwing it up, but i assure you it is correct.
using System;
class ReadStr
public static void Main()
Console.Write("Enter your name:");
string szName = Console.ReadLine();
Console.WriteLine(" Hey "+ szName);
i figured out the problem. there was an issue with my VS2010. i greatly appreciate your help tho!
