sarkarshomit
These are the stuff that i ordered:
Cabinet: Cooler Master Storm Stryker
Mobo: ASUS Rampage IV Black Edition
CPU cooler: Cooler Master Seidon 240m
GFX card: Zotac Titan Black
PSU: Cooler Master Silent Pro M2 1000W
now i am in a kind of a dilemma that the Stryker comes with a top mounted huge fan.
will i have to remove that to install the rad of the cpu cooler i am planning to fix, or will the rad be able to reach out to the bottom of the cabinet without the GFX card of not being much of an obstruction.
The PSU being bottom mounted, if i fix the rad at bottom floor of cab, then i may have to remove the tool box of the stryker, but thats fine, but top mounting the rad, i dont want to part away with the original fan supplied by CM. i cant even install that fan to the side panels as done in HAF as Stryker comes with a clear window....any tips for my situation...anything atall...Thanks in advance.....
Shomit
Shomit
