This is using a stock 1800X with 3000MHz ram
1) Stock Motherboard voltage goes up to 1.568V! ive had to use a huge offset to keep it check. not good for new comers, you can see 1.5V in the picture this happened alot, every minute it would just jump to 1.5V
2) The Smart Fan control is actually very dumb, gigabyte use their own sensors for temperature readings that are very offset! i understand they wont be close but theirs a very large margins
Gigabyte CPU sensor is 15C offset from the real CPU Die of ryzen. why not use the Die temp you read anyway??
Gigabyte GPU sensor is 8-24C offset from the real GPU temp, not a big deal but its much more offset than ASUS
3) The BIOS is horrid to use & mouse movement is very flaky. goes from extremely fast to not moving at all.
4) Plugging in my Ircam IRDAC to the DAC port turns off the GPU Signal for 3-4 seconds
5) If you run HWINFO software Then turn the PC off you have high chance the board will no longer turn on, this has been documented but i found out the hard way last night. ran it for 6 hours turned the PC off in a perfect condition next day NO power nothing. Battery Removal had to be done.
So theirs my Thoughts. Hopefully this will help some in decisions in the future.
For me no more Gigabyte Motherboards, Rather go back to ASUS an have longer RMA's & working BIOS/Fan control
