paulstung
I'm waiting on a few goodies for a new build, it is based around the Pentium G3258, and is going to be black and orange, but I need a graphics card, nothing to special, just something mid range. The machine is going to be primarily for teaching myself the more nitty gritty side of overclocking, and for basically a console type experience, were I can sit on the couch and game in comfort in front of the 50" plasma.
So I'm looking at the R9 270's, the first card that comes to mind is the sapphire R9 270x Toxic OC, being black and almost orange is great nothing much to change there, and the other card is the Powercolor Radeon R9 270X Devil, it's black and red, but again nothing much to change with that either, they are both a simple fix, with removable shrouds for painting.
The Devil is clocked slightly higher, but I should imaging they will both overclock close to the same end result. So it probably boils down to brand hard on's, customer service, and warranty's and stuff. Has any one had good bad experiences with either manufacturer, or are they both OK.
Cheers guys.
Cheers guys.
