SEBAR
I love it, very unique.
That copper has made me dribble all over my desk lol.
Is there anything that needs to be considered when using copper in the pipes like you have?
Also the front panel how easy was that to get fabricated? I want to do something with my C70, including building a cage of sorts onto the top out of sheet brushed aluminium along with a similar front panel to yours but i will have vent holes for the fans but just a circle pattern for the dual fans a logo etched and new missile launch buttons for the on and off, with blue/red illuminations around the bases.
Sound too tacky?
Again love this effect.
Thanks, The copper tube is fairly easy to fit and bend. Just get a little extra for errors. Also you will need a good set of benders. You do not need a super expensive set but the cheap ones will kink and mar your tubes. I had to do some mods to my benders to prevent this. The front panel was not to difficult but the copper is not forgiving at all. I measures and drew a line with a pencil on some blue tape where I as going to cut the optical bay covers. I ended up changing my mind and left the front panel as one piece but the line I drew made a line in the copper that I was never able to get out.
Your project ideas sound good, how soon will you start this project? I love C70 build. I am still using my C70 build as my main PC.
