SEBAR New member Feb 18, 2014 #82 MathiasBE said: For the copper pipes, can you use any copper pipe with the correct measurements? Btw amazing build, have been following ever since I joined the forum! Click to expand... Thanks, the copper that I use is the rigid copper but I have seen people use the flexible stuff. I think that as long as you are using the correct diameter of tubing it does not matter what kind. Conchubair said: looks like too much copper mate, it looked better the other way... Click to expand... Thanks, it is a lot of copper, this is just a test so I may be making some changes. Feronix said: Nice touch! :dribble: Click to expand... Thanks bro, mostly sparked by your suggestions. . Next up I may try and work on the window. I have come to realize that the window I cut is a bit small.
