Call Of Duty 4
name='jordan835' said:
In multiplayer my radar/HUD is not displayed, does anyone know how to fix this?
Some servers have it turned off as "Hardcore mode" or something dont they?
name='marcus000' said:
I updated PB and then when I joined the server it said I was banned... theres an easy fix though.
Just copy and paste your player folder onto your desktop (mainly as a backup in case anything goes wrong).
Go into your settings and use the keygen from the download to get a different key, enter this different key and join one of the servers. Exit the server and make sure that the key you are using is the new one.
It worked for me anyway :)
PS: Im noticing Punk Buster is kicking a hell of a lot of people off the .86 server.
errrr what keygen?
lol? i think he may be takin the p1ss saying u have a downloaded version?
i dno
lol
ur guess is as good as mine xD
Yes it could be that he is playing on a hardcore mode server in which case the HUD is removed. Else it might be that it has been disabled either by a modded server or a pb setting on a server in which case you can use:
/hud_enable 1
In the console!
To Nepas,
The following has since been added to your pbbans information,
IP Address(s) (2)
12.201.77.72
81.111.62.130
Alias(s) (4)
ArtificialAim
Deadly
FreakyFreak
[OC3D] Nepas
The above basically means that the names and IP addresses have been associated to your GUID, but the violation they have was using IP 81.111.62.130. Do with the information what you want. That is all the information I can gather, you can take it up with them if you wish however that GUID has been banned and for an aimbot violation is unlikely to be removed from any banlists. The easiest and hassle free solution is to get another copy of the game if you wish to play on legit servers.
The second IP resloves to the states, and checking the names of the other players on gametracker also shows use of USA servers.
http://www.gametracker.com/player/F...=1&game=cod4&loc=_all&min_score=&min_minutes=
http://www.gametracker.com/player/ArtificialAim
http://www.gametracker.com/player/D...=1&game=cod4&loc=_all&min_score=&min_minutes=
I withdraw my previous accusation and apologise if indeed you have not cheated. This is potentially what could of happened but even that being the case the EULA for the game does not cover the theft of cd keys.
Potential senario.
You have given somebody the cd key or they have used a generator or somebody has and they purchased the key. That aside somebody else is using the same key on a USA IP address with those aliases above, it could be that they got the GUID globally banned through punkbuster. You have then attempted to load in to a server that has punkbuster enabled and you have been kicked it registered as an aimbot violation the GUID was banned for and the server was streaming. That could be the cause for the entry on pbbans.
That is a possible senario, you can take it up with pb but it would appear that the GUID has been used for cheating and it is unlikely it will be removed who cheated I have no idea it could have been you it could have been somebody else. I am not going to go in to cross checking dates etc as it could be just as likely a senario that you have given the key to somebody else after any violation, note it is just speculation if you want to delve in to all that to help clear your name then feel free.
many thanks for that mate,i think i will definatley dig down into this,but like you say i wont have muck luck but am going to try anyway
Meh, I just got callvote kicked (temp banned) from the overclock3d.net cracked server again. This is on the server with IP ending with .86 and my player name is Frakt.
Can I please get an un-ban? It's only noobs callvoting the kicks and noobs voting yes because I have more kills than them.
Someone calls the vote, 7 ppl just spam f1, and then 3 ppl vote no, I say I'm not cheating and ask them to look at kill cam, and I get a reply "yeah I know" and then I'm kicked+banned because the vote passed.
Does anyone know of a better way of searching the server list (other than scrolling through them for 20 min and after about 4 refreshes) to find the server your mates are on??
Would be really good if they put a "connect to IP" in the next patch update :stickpoke activision :stickpoke Infinity Ward
Erm...you can connect by IP....
Press the ¬ key in the top left of your keyboard (Below Escape, above Tab) and simply type connect server IP
Didnt know that,
thanks :D
mmm I borrowing this atm, tried running it with 4x aa yesterday that lagged a bit at points.. moved down to 2x aa and now I get 60fps.
Gamespot hardware review helped a bit.
I am finally a member of the Mile High Club after doing the Epilogue mission on Veteran on my Xbox 360!
It took around 20 attempts, after around the 10th I reached the hostage but missed and then I finally did it.
Time to calm down :p
Nicely done.
I haven't had time to do the single player yet.
The challenges on MP are taking up enough of my time as it is.
