rossi94
they actually have a premade one for fc6
http://www.coldzero.eu/product.php?id_product=1003
But there is no DVD place anymore, just for the Lamptron and the Lamptron display.
Yes, if you want the Lightbox just request it you can find costum requested parts in the shop, he makes everything - don't be shy.![]()
I dont need a dvd slot since i dont use an internal optical drive, but i have mixed feelings about the fc6 one because i dont know if i like just having the screen and knobs sicking out only. i know it's more clean looking but still but 100% sure about it because i kind of like the fc6 faceplate.
You could create your own midplate. You could have a slot for start + reset switch over the drive and lamptron or for a 3,5" card reader - or something else, that's small or just leave it empty if you want the front costumized he will do it. I don't think he will even set the prize higher - have friends who made really good expieriences with him.
Or if you don't want it remove the hotswap dock and include something else in there or just create your own reservoir and mount it in there that you can see inside it through a plexiglass wall mayby include a fillport ... endless options![]()
that sounds appealing -- i really like the sound of those anti vandal switches tom was pressing in the merlin video off camera -- even the less nice lamptron switches on the merlin sounded good to me, since the stock switch on the 650d makes no noise at all and like i said is so still you can hardly even press it.
If you do end up installing some custom switches at the front or top somewhere, what happens with the stock switches? Im not too crazy about having a set of switches there not doing anything, that's the only thing..
Include a turbo button, who maxes all fans for oc![]()
My System is laying on my workbenchI will post pics, after my modding is done - I work to slow for a worklog
Looks very niceI have almost everything here and planes are there too, and a full 3D model, mayby I will upload some pics of that later okay?
Plans are - self build top reservoir - full power supply sleeving - selfmade watercooling blocks for my dominator rams - mayby a Slight - new reset and power switches - case addon including a mora 3 core - mayby installing the aquaero 5 on the top of my Lian Li PC-V700WX - mounting the window to the inside - include a own aperture with a lighning ROG logo - swapp all the fans - include lightning (cold cathods + leds) - recolor the fron usbs from blue to red - own interface to connect the 9 fans on the mora into the case easyer and keep the clean look
some of these steps are already done, it's a long way ..
atm I try to figure out how to color the copper of the ram coolers black with potassium sulfide.
It's no real mash, just holes. I love it .. really but it's very small so it's quite hard to mod..
Yes, I were - I wanted a light small ATX case, because I'm often on lanpartys![]()
Awesome news, me and my friend are building a cnc milling in the near future and will be able to produce our own watercoolers and plexiglass reservoirs (out of one part + topplate). But I don't want to wait for my topreservoir
