rossi94
also this is a small thing but im happy thsi card does have those extra holes at the rear of the card so i can zip tie the gpu power cables to the edge of the card like tom did in the koolance cosmos build
Picture link is broken
That card fits in really well
really nice build![]()
Hi, I have also just carried out a new build in a 650D and the one annoying thing is the power button. You have to press the button really hard before the machine turns on. I noticed you were having the same issue, did you find an alternative? I think the button has been badly designed on corsairs part and is really cheap and flimsy if you remove it from the front panel. If I cant find a replacement it will have to be modified to work properly.
Very nice build mate
Ohh I miss my D14. Let me give you an advice: If you're running those D14's fans on lower (L.N.A. cable) rpm NEVER change that cooler. I'm sure you could be tempted by a cheap used H100(i) but mate, DON'T! The pump on those kits alone, is louder that the whole D14.
I moved from a D14, with it's lovely stock fans, to a H100 with NF-F12. That H100 was - THANK GOD - a gift. The unit was a good one (no clicking noises) but it's just louder. It just is! I could hear the pump over all of my case fans and the Enermax PSU.
So last Monday, I sold the D14 & H100 all together, to get the new H100i. The 2700 fans are a joke. I put my trusty NF-F12 on that too, and yes it's ~3 C cooler that the original H100 but I can most definetly hear the pump noise again :/
The hole D14->H100->H100i was a real blow off. I think I'll get a new D14 in the near future, after all :crazy:. I'm considering a simple custom loop too, but I don't believe that I'll get any higher overclocks out of my 2600K. 4.8GHz @ 1.38v is rather good and the voltage seems safe. The next "milestone" (5GHz) comes at 1.46 which is a tad high for 24/7 imho.
So bottomline. People, you have a D14? Keep it! :hello:
The AX850 is lovely due to the fan which stops, too
Yeah, I'm not into Corsair that much, either. Sure they had -and still do- some great products, but I feel they are choosing rather cheap OEMs from time to time. In my opinion, Noctua is in a different league, quality-wise. Take a look of the metal itself on the mounting bits, and then look that flimsy H100 backplate and you'll agree too
Don't get me wrong, I appreciated a lot of corsair products through time (the micron ddr2 Dominators, the Hyper 2000c8 ddr3 ones, some good PSUs etc.) and I love the good support they provide, but I think it's rather naive to choose a Corsair product, just because of the brand. I see people to "corsair only" build I just don't get it... :lol:
What problem do you have whit the "MSI Z77 MPower" ?..
Damn, that is not fun :/
