andrevautour
Hey -- So I am a small question.
I need to run a molex from thje psu up the the top of the case to power my Lamptron fc6 unit. Currently I am using the 4X molex that comes with the corsair ax850, and i use the molex at the very end to power the fc6. The problem with this, though is that there are 3 spare, unused molex connectors around the back of the case, and I would really like it to be more clean. So what I would like is the get a single cable that is the same length as the 4X molex corsair gives, but only have one molex on the end, that way it will be more clean around the back and get rid of those 3 unnecessary molex connections around the back panel.
Does anyone know where I can order a custom molex cable for ax850?
Thanks
Thanks
