alxcsb
It is an older Core 2 Duo machine, a Toshiba Satellite P200-1EE, which translates into a Core 2 Duo T8100 CPU, Radeon HD2600 Mobile and 4GB of 667MHz DDR2 RAM. Now, because I can't upgrade the GPU or the RAM, the only thing left would be the processor, but the ones that are decently affordable are only around 5-10% faster, and the properly faster CPUs are close to 140 quid, which is too much money really. So, I was thinking about changing the mechanical HDD with an SSD. Would that work or is the mobo going to have issues running it? And if you guys think it would work, would it be justified in terms of performance? I only use the laptop for surfing, a movie here and there and the odd gaming session, but nothing upwards of Torchlight 2 or World of Tanks @ minimum in terms of system requirements. Thanks for any ideas.
