Marcos Viegas
Liking that new front panel.
The dogtag, not so much. The round edges are not very... round, sorry.
The engraving doesn't look good at all. Apart from that I'll be looking forward to what you do next![]()
Thanks, it was my first time that I engraved on metal, so it was not perfect, I still have to train more, but as the project has to walk, I'm learning and working at the same time ^_^
Those bullet holes can also act as air vents.
or dust intakes.....
Haha! :lol:
You guessed it... :lol:
will need to make sure to have a positive airflow in that case.
liking the look so far though![]()
the case will be well ventilated, further ahead you will see what I will do ^_^
Is that engraving done with a vibration type engraver?
you can get very small diamond grinding bits for the dremel which may help you as they are like using a pencil on it
Thanks for the tip, next time I will do with a little more care, but for now, the idea is to make something that looks more "gross", looking like it was done hastily, as a dogtag engraved on the battlefield.
So let the news...
Engraved made in front of the case:
Front with the switch:
I did not like the look, so I changed the location of the switch:
How was a hole in the front, I added a medal (which is the Battlefield 3 but it will serve):
I hope you enjoyed.
Next step are the feet of the case.
I thank all who support and follow the project!
