Antecs are just like Thermaltakes.
Marketed at people that dont know any better.
For the money you spent you could have had a really nice case, but you bought crap
I agree that the 1200 is likely the weakest of the lineup, people expect more from a full-tower these days. Still, the 1200 is a pretty old case now, about time they updated it.
I have a couple of Antec 300 cased PCs, purely using air cooling, and they've proven great for the role they are in - basically older PC parts in server-type roles, plenty of HDD's cooled by air. They've proven easy to build with (hinged, removable doors, hinged removable front fan mounts) and cheap. NOT something that'd ever case one of my gaming rigs, but good for the job they have.
I also have the original Antec 900 case. It was my main PC case at one point and it proved to be a good match for my old overclocked Q6600 gamer on air. Now that same system is crammed full of hard-drives and works well as an always-on server...it's quiet (light whoosh of air moving is all) and stays cool.
I think the lesson here (sorry, not preaching, you've learnt it the hard way) is to do you homework and know what you're getting. My friend has an Antec 1200 case running as an air-cooled server crammed with HDD's and it's fullfilling that role perfectly for him. Appropriate case for the job is key. Also, Antecs used to be pretty cheap hence part of their appeal I guess...
I do have a sneaking suspicion that Tom doesn't like them though...call it a hunch if you will...
OP: Best of luck, hope you find something to meet your needs.
Cheers,
Scoob.
