BigDaddyKong
Active member
I started out with a Fury on my old system, then moved to a Crossfire setup. A year later I built my 1800X system and moved them there. About 6 months in, my new Fury stopped working. No problem, I RMA'd it. It was about 2 years old at that point. I get used to running a single Fury, and decide to ditch Crossfire. After a few weeks, I got a Fury back from RMA, and put it in the system. About 3 weeks later the RMA unit stops working. So I put the used Fury back in my system I got earlier and did another RMA.
When I got that RMA back, I decided to put that one in my sons system, which was my old 980X rig. Still running great. Last night when I got home from work, I was just surfing, and boom, screen went black. I tried to reboot, and got a code 66 on my Crosshair Hero VI. I tried swapping PCIE lanes, still no good. I pulled out an old 390 and stuck it in and it worked. Luckily, I had a 1070 in a prebuilt system I got for my wife. I was able to swap the 390 and put the 1070 in my system.
I am running triple monitors. I noticed over the last couple of weeks, the monitors were not very bright, and not all that sharp when looking at them. I noticed with the 1070, with all 3 monitors hooked up the memory stays at high clocks all the time. I did notice when I did get the 390 to boot, it was doing a windows update. Could running 3 monitors lead to an early death of a GPU? I did swap out my power supply between the first two RMA's after a silly accident with my water loop, I know its not the PSU killing them.
I did OC my CPU, but never the GPU. The only other option would be the mobo. But its so random, with nothing changing in between, I'm not sure about that one either. Maybe this rig is just jinxed, killing 3 GPU's in about 7 to 8 months.
