Cydia: That is yet to be decided, but there will be a way! The best way to do it is very tricky, so want to do something easier. Though that will all be a surprise so keep a look out
YUSS 3 days off from work!
Will get as much done as I can, but thought I would give you guys a quick we update
It is time to sort out the exhaust fans for the right side of the desk, and take into perspective the PSU size, as well as my front bits (fan controller, some switches and a Blu-Ray drive)
Happy with where it was sitting, I started to mark everything up, hoping it would allll be perfect!
As you may tell from the next two pics. The two sides have different measurements. One side is to make the fans sit in a rebate in the wood, and the other is so that the Bitspower 240 Grill will sit FLUSH against the wood. This is where my router becomes very handy
Time to start the jigsawing here is the first pilot hole. This time wanting to be more precise then the last so will cut a bit slower to contain a straight line. The blade will never run PERFECT which is why again.. The router fixes everything!
All the pilot holes drilled, and some jig sawing commenced
Not 100% perfect, but after the router has done it's job it will be!
Time to start the rebating process. The wood is 20mm thick, so -4mm for the 3mm grill, and then -9mm for the rebate you will be left with 7mm of wood and the fan will be sticking out 18mm which then the fan will be able get screwed using taping 6-32 screws when the time comes
Going down in small steps at a time, as you can see from the different layers in the top right
All went perfectly! The fans all sit at the same height in each corner, and fit in there nice and snug, barely needing to use any screws! And no, the propellers do not hit the outside casing so a top result
And this is how she sits!
Note: Every single cable in the desk will be made to a custom length, EVERY SINGLE ONE!
Next update should be: The construction of the lid itself
Then it is all about the small things from then on and all very straight forward..
