K
		Kyle
Guest
good luck
			Nice Idea and good luck, maybe it's too late to say this, but 92.5 cm is very high for a desk, I'd say 75-80cm is normal
	How do you add the pics of the components to your sketch?So it begins!!
Conceptual design
Here is what the timber looks like. Is native NZ Rimu. Please excuse the end one with the bird poo, that will be sanded off in due course. bloody sparrows in the shed >.<
Cut some of the pieces to length of 650, after everything has been glued together will refine the length to 600
Tools for the job. PVA glue, biscuits. annnd a... Biscuit cutter? (who cares about its real name biscuit cutter sounds cool)
As you can see, there is some light inbetween the boards, so a nice plane on areas will help close those gaps up
Some fellow putting the biscuits into their grooves after a nice layers of PVA Glue.
All clamped up, with some weights on the timber to stop it from setting wonky
This here is ONE side to the draw unit
will get the next one done on Sunday, after I let this one set over a day or so!
CRAMPED* See here*clampedI love seeing someone work with wood instead of the usual metal and acrylic
Much more skill involved
CRAMPED* See herehttp://www.woodworkersinstitute.com/page.asp?p=605
But I agree! more work and skill involved in wood, more factors to put in when assembling too
	Yum yum, lolMint sauce!!!!!!!!!!!
