Updated my cable management
Ghosthud1
i got busy today as its my first day of the 10 week holiday i have weeeew
what i did:
Cut hole for CPU 4 pin power
Cut hole below 5.25" bay
Cut Hole on the last 3.5" bay
Flipped the PSU and cut a hole for air circulation
Overall i think it turned out superb.
yeah its all going to be internal and im going to start to cut out the front of 3.5" bays tommorow morning, then i can fit my SSD's on the back of the case as its my lan machine.
It is just possible as there have been some others doing it.
I havent cut any holes in my case. Its pretty neat for stock. Way worse that yours tho dude.
my antec 300 is going to be alot like this but without the whole 3.5" bays ripped out, im just gunna chop abit of the front bays out, and mines only going to have 1 240 rad and not two ^^
thanks for comments guys very well appreciated
and about the front of the case i'll be cutting about an inch out of the bay area with a dremel, i've had enough experience with a dremel to get a straight line so all should go well, even if its an uneven cut u-channel edge moulding is great for hiding it :D
what i did:
Very nice looking:) jus a quick question, what did you use to cut the holes for the cables? If a cutting disk which one?
Cheers
Stevej696
