Dicehunter
Resident Newb
Tweakforce have been going for quite some time and with nearly every driver release they try and squeeze a little bit more out of the driver weather it is a tiny bit more performance or increasing the IQ overall, Always worth a look.
In this update they have tweaked the following, I have it installed and it runs perfectly, Be warned though it is only for 64 bit systems -
- Paletted Textures In Video Memory
- Render Quality Flags
- Target Flush Count
- Texture Clamp Behavior
- Texture LOD Bias
- Use Cached PCI Mappings
- Texture Memory Space
- Downloaded Memory Space
- Texture Precache
- UMA Fast Frame Buffering
- Main 3D rendering
- Triple Buffering
- Area Anisotropic Filtering
- Supports Geforce 400-900 Series Cards
- Compatible with Windows 7, 8 and 8.1
Physx, HD Audio, GeFroce Experience, 3D Vision and Miricast Installs have been removed so you will need to download those separately if you want them, GFE is available from Here and the latest Physx release is available from Here, HD Audio and Miricast drivers are not available separately as of this moment but aren't really needed if you don't run audio through your monitor or Stream to an Nvidia Shield.
If you are a Windows 8/8.1 user please remember to disable driver signing by following the guide here -
Or if you want a more permenant method you can disable driver signing completely by typing into the start menu or start screen "CMD" right click on it and run as administrator and paste the following lines in and press enter -
bcdedit.exe -set loadoptions DISABLE_INTEGRITY_CHECKS
bcdedit.exe -set TESTSIGNING ON
Now reboot your machine and driver signing is now permanently disabled.
Before installing it is highly recommended to uninstall your current driver and then do a driver cleanup using the latest DDU which can be found Here
And finally download the driver here -
Windows 7/8/8.1 - Click Me
Source - TweakForce
