TTL sets his fans up on full 12v so my question is this. Taking 1 peripheral cable from an AX 850 PSU that has 4 Molex 4 pin plugs on it, how many 140mm LED fans can you run from each plug and how many can you run from the whole cable without power drop to the fans or over loading a plug or the whole cable.
I have 7x140mm LED fans to power up so I would like to piggy back as many fans together as possible to one Molex connecter/peripheral cable to keep wiring as tidy as possible.
Thanks.
Thanks.
