T Toxcity New member Sep 3, 2007 #21 name='BloodRed' said: Aaah good ol' tea towel, did you find out what that... thing was? Click to expand... Yep, the tea towl did the job well! What thing? :eh:
B BloodRed New member Sep 3, 2007 #22 You know, the weird bit in between some of the pins, you tried getting it out with a.... can't remember, but did you get it out?
T Toxcity New member Sep 3, 2007 #23 A bit of thermal grease got stuck in the pins.. Ran the CPU under a tap.. sorted!
Rastalovich New member Sep 3, 2007 #24 name='Toxcity' said: A bit of thermal grease got stuck in the pins.. Ran the CPU under a tap.. sorted! Click to expand... If u`ve really done that - air it for eff sake. The pcb with exhorb moisture atleast. Going back to another thread.. why not just take the hs off
T Toxcity New member Sep 3, 2007 #25 lol, yeah I let it dry off in the airing cupboard. And in answer to your question Rast, I am not as daring as you might think!
B BloodRed New member Sep 3, 2007 #26 name='Toxcity' said: A bit of thermal grease got stuck in the pins.. Ran the CPU under a tap.. sorted! Click to expand... Awesome, that stuff gets eeeeeverywhere :S
