The Hive.
AlienALX
Active member
So we've now had three Alienwares built, water cooled and modded. It's finally time for me to use a NAS so I can tie them all together. This shouldn't be an epic big build but it is an important one.
I've been looking at getting a NAS since the year 0. Thing is I've never seen one I like the look of. Not so much not like the look of, but don't like the look of the cooling situation. Most have poxy little fans that would drive me nuts. Any way, recently a friend was selling his Dlink Sharecenter for £20 so I bagged it.
I did ask him about the noise and he said it really wasn't nice. After doing some more digging (reviews, customer comments etc) I realised that I did not want to run it as it is, which is a shame because I am almost loathe to cut it up as it's really rather pretty. However, noise just does my head in these days so I decided to buy it and then buy an ITX case or something to mod it into, so I could remove the bumblebee fan.
About two months back a company called Kolink released the K6T. It looks like this.
And the back.
Now originally I wanted one of these.
Quick explanation. It's called a Graphics Amplifier, and is basically one of those external boxes for a GPU to go in if you are using a laptop. There was a load of them on Ebay at one point for £100 or so (which I guess I would have paid) but lately they are all silly money (like £300) so I decided to go with the Kolink instead, modding as I went.
OK so both the NAS and the case arrived today and I was very pleasantly surprised. The case (Kolink) is one of those rare examples where it actually looks better in the flesh than it does in photos. Usually a cheap case looks OK in photos then rotten in the flesh but this is the opposite I am glad to report :) it is also far, far smaller than it looks (I would not even try cramming a MATX board into it) which also eased my mind a little.
OK, so obviously this isn't going to be a very long project really. Well, not unless it gives me any headaches. My main plan is thus -
1. Get a crap PSU to fit into the case to run the LEDs on the front (more on that in a sec) and possibly run the NAS also.
2. Mod the case to take the NAS guts and a 120mm fan instead of the bumblebee.
3. Make cover plates/panels to close it up.
4. Possibly add some internal lighting, though I am not decided on this yet. I have plenty of options (including a set of purple cathodes etc etc) but I am not fully decided yet.
5. Either leave the clear side panel as it is and use internal lighting or repaint both panels in flat black (so they match).
The first thing I did was pretty much rip every last part of it out. I then tested the LED panel (it's 5v) and got a nice surprise. I didn't realise that they are active LEDs and slowly chase 7 different colours around the front. Vid.
https://www.youtube.com/watch?v=GA9VkogT1HE
Apologies for the racket. That's open back headphones for you, might want to mute the vid.
Also to note, some of the LED colours appear only as white, so the vid doesn't really do it justice.
Next job - gut the NAS.
Looks good. What HDD's are you using for the NAS? Hope you have better luck with D-Link, than I do, it tends to be one brand I avoid, as everything I've ever bought from them either breaks or doesn't work properly...
For now a couple of laptop drives. I only need 100gb tbh that's about all I have (music and films) that I want available to all of the machines. IIRC they are two 250gb, though one may be a smidge smaller.
100GB? I have more than that on one iPod. The downside of living in Crapinternet. Local storage due to povo streaming capability.
It will be great to see what you come up with. I like the idea of the GPU enclosure but I'm sure it will be interesting to see the K6T. :)
mmm don't believe you. :)
haha you suspicious person you :D mad thing is, you're actually right. It is far more than 100gb :o
I've been buying 99p CDs lately like mad, so it's now this big. Plus side is i get to give my mother the CDs once I am done as we share similar music interests (though I would not give her any death metal lmao)
Which will fit on one drive. As for the rest? just some old 70s movies.
Then you'll want to mirror them - so that doubles it...
I'm not sure they are the same size. One I know is at least 250gb (poss 320) and the other is possibly either 160 or 200gb.
All I want to do is be able to play my music from one place, rather than having to copy it onto every PC and then of course them all falling out of sync when I either download or rip something new. I do have some cleaning to do, as I have basically spent the last year replacing all of my MP3 files with either FLAC or WAV and haven't kept the tidiest of houses :)
Quick update before I go out. Here it is all stripped down. Still got some more to remove yet.
Trying go give an idea of size here.. Erm, here it is next to the router and modem. It will live on the floor in front of them when it's done.
Just a quick update. Been doing research for the most part, and digging for things to use in this. The PSU arrives tomorrow (I missed the delivery) and without that I can't really do much. I have started to make some parts though and hopefully should have some more pics soon. I've decided what I am going to do with the insides too, and what colours to use what braid etc.
I found a nice 8mm latching switch I am going to use as the main power switch also.
Modding has begun. First I got some tools and a piece of acrylic I cut to width a couple of days back.
Marked it so I could cut it to length and the centre point of the hole.
Lower front panel.
Cut to length.
Plastic weld.
And a short while later.
Thanks buddy ! it won't be done quickly I don't really feel up to anything serious right now. Just pottering along trying to stay away from the dark...
I deliberately ordered two piles of stuff for projects this month so I had plenty to do.
Hopefully shouldn't be too long before I can paint the side panels. That's the biggest job really.
