watch out when dipping your case. It has a soft touch finish right? it could happen that plasti dip will barely stick to it and might even fall off again completely. I had the same issue on a GPU once.
Question guys, can you get that underglow effect with the DDR4 Dominator modules?. Ie, not to have those cutouts on the bar, but rather have the solid bars installed. And also have the light bars installed, for that nice underglow?... Just simply not "see through bars"?.
absolutely cracking build dude! Super neat!
Looking forward to seeing how it progresses.
Nice overclock too although is that your best voltage? It's possible coz I currently run 4.6 on my 6600k at 1.365 vcore and I know anything higher required a bit more of a jump in volts
just please please please take off those combs after the cables set. They just look way too big.
i like combs here, and i think now this liquid cooling is usefull. (GPU)
to reply to the previous questions :
i said i5 doesn t need liquid cooling because there s no point spending so much money to cool it.
all quad cores cpu too (i7 quad on low sockets) are not worth the money to watercool em.
With the same amount of money it s better buy a 6/8 core cpu: they can destroy em in performance.
I dont like the combs because the spacing between the cables is much larger than when they come out from the connectors. If the spacing would be tighter they'd look much neater but I still prefer trained cables without combs. I'm also sorry I was a bit offensive in my first statement.
Really liking the black tubing. Very stealth!
Also for the cable combs - I don't mind them but I see where TPC is coming from. I would probably go for a matching colour or clear instead of contrast but hey that's just my preference. I have zero cable skills myself.
This is turning into a really sweet build. It started nice anyways but really liking what you've done since you first started the thread.
