Destiny : evolution
Mageta Lion
Hey all :)
The last version of my TJ-07 rig was build when Sandy-Bridge E came out and it had a 3930k. Now its time to build a new version. Here is the full spec list of items that will be used:
Destiny full specs:
System hardware:
motherboard: MSI X99S Xpower AC
Memory: Corsair Dominator Platinum 16 2666
CPU: Intel Core i7-5930K Boxed
SSD: Samsung 850 Pro 256GB 2x
GPU: EVGA GeForce GTX 980 4GB 2x
Case and parts coldzero:
case: Silverstone TJ-07
TJ07 part: Custom motherboard extended motherboard tray
TJ07 part: custom PSU backplate
TJ07 part: custom motherboard backplate
Tj07 part: custom 5.25 bay side panels 2x
Tj07 part: custom midplate
TJ07 part: custom lightbox
TJ07 part: custom frontpanel Destiny + lightbox
TJ07 part: custom smoked glass top panel
Watercooling parts:
Radiator: EKWB coolstream 480PE
Radiator: EKWB coolstream 240PE
Radiator: Radiator Stand 240 - Black
Radiator: Radiator Stand 480 - Black
Pump: Laing DDC-1 MCP350 12V 2x
Pump top: EK-DDC X-TOP CSQ - Acetal 2x
CPU block: EK-Supremacy EVO - Full Nickel (Original CSQ)
GPU block: EK-FC980 GTX - Nickel Acetal 2x
Reservoir: EK-RES X3 150 Tube Reservoir 2x
Acrylic tube: Acrylic tube 12/10mm black bitspower - 50cm
Liquid: Mayhems Pastel - white - MD-P-SY
connectors: EK-CSQ Adapter 45 degree G1/4 Black
Connectors: EK-CSQ Adapter 90 degree G1/4 Black
Connectors: EK-HDC Fitting 12mm G1/4 - Black
fans: Corsair AX120 SP 6x
PSU + Cables custom ICEMODZ:
PSU: Corsair AX1200 profesional series
PSU: Custom Psu 24pin Cables black/white
PSU: Custom Psu 8pin Cpu/Eps Cables black/white 2x
PSU: Custom Psu Pcie/Gpu Cables black /white 4x
PSU: Custom Psu Pcie/Gpu Cables black/white 2x
PSU: Custom Molex Power Cable for Power Supply 2x
Here some pictures of the hardware when I was unpacking and for those wondering here is my previous version of my Destiny rig:
http://forum.overclock3d.net/showthread.php?t=58374
Today Took the case apart and painted all parts that I use again Deep Matt Black.
also made the radiator stands fit, so had to cut a piece of. And the midplate is modified to inverted ATX. Tomorrow going rebuild a part of the case, going to put the radiators in place and pumps. cheers :)
Instead of going with the standard pump and housing I upgraded both, so now there ready for tomorrow when where going to place them.
Today did a couple of things, checked the paint works from yesterday, and I am really happy about it :) Then started on the radiator stands, there both fitted now and tomorrow going to place the pumps between them, already marked the spot where they come.
Also worked on the custom extended motherboard tray with the murderbox backplate together with the murderbox PSU plate. All is ready to be installed now :)
attachment.php
DAMN thats a big case, look at how big it is compared to the doors behind it!!! :p
Haha, I clicked on the link to this thread thinking it was some kinda new game. To my surprise something even better.;)
Really looking forward to seeing your completed x99 build.
Today fitted the pumps, radiators with fans and installed the mid plate. I think it turned out really great so far, and happy with the way the pumps are placed. Even used acrylic tubing to fit the pumps to the radiators.
End of the day we installed the mid plate and I put the motherboard tray in to see how it looks :D
