Lighting pt1
I originally planned to go all black with black tubing for this build with some descrete white lighting but as the U2-UFO is more of an 'in your face' case I think it looks a little sterile for my tastes with such sublime styling.
So as the name suggests I have gone for an orange and black look. Sourcing orange lighting is a total pain and I see now why it isn't a very popular colour to go for. Just about the only lighting I could find are orange led's and even those wern't pre wired so I decided to do it myself
I picked up a few LED's from Maplins and scrounged a few of a couple of friends. Some turned out to be amber coloured which didn't really suit my needs others were the ones I was looking for so on with the testing. I intended to use the LED's in the alphacool pumps and the bayres's to light up the plexiglass as without any lighting or UV fluid plexi will look dull so here goes:
Heres a template of the 2 bayres's I intend using with the holes marked for the led's :
With the wires cut to length I temp attached them to the led's along with a resistor and then wired it up to 12v and ground on the molex (yellow and black).
Once soldered up and sleeved I then went about fitting the led's to the res which is pretty much the look I was hoping for
