I am just about to start on a new project so thought it might be an idea to make a little log of it. Hopefully it might interest a few people.
A few of you may have seen my last build :
Although I did really like my old setup I felt that the green/blue theme had been done to death. It was also very bright and became a little distracting, especially when gaming. With the fans being blue LED version, alot of UV blue reactive kit, blue gauges, fan controllers etc so the looks needed a complete overhaul.
My watercooling kit is top of the range stuff so I would be keeping that although it did need a damn good clean after 6 months of none maintenance aswell as a little spruce up - more on that later.
I love the UFO case and just can't rate it highly enough. It makes building a rig very easy (though expensive) and although the accessories it comes with are sparse to say the least, all you need are fans (9 of) to get you going. I will once again also be using a dual loop watrercooled setup so using this case again was an easy choice to make. Being black it goes with almost anything and for watercooling there just isn't a better case to use on the market (imo). I know it isn't to everyones tastes, being more industrial looking than lianLi and silverstone, but its a look I like.
As the name suggests there will be a splash of orange (visually, not physically I hope) as I don't believe orange is widely used - I guess for good reason judging by the hassle I am having sourcing parts. It will however be a little more descrete than the blue/green effect used previously!
Before I get onto the actual building though I have a little prep work and cleaning to do so I'll update this when its done. Pics to follow
