Those little annoying F@H things ..
Do you think it has something to do with the changes being made to bigadv?
Yes i think so.Got one small 1473 points wu,and a normal big wu 6901 now.No 6903 or 6904
Lost a few SMP WU's and i am not 100% if they ever came through ,
Oo wait i lost all my WU's , including the GPU's
bummer........
I was still living in 2010
EDIT SO just a little reminder DON'T put back the time if you still have a few WU's left to be folded or they WILL be deleted and the tracker will get NEW WU's ...
and to think of, this wasn't my first time
/Carries on.....
anyone else getting the 6099 WUs?
pain in the back side, takes about 13 hours for my i7 920 to complete one and the last time i didn't even get any points
all i seem to be getting today
My HFM.net says around 19K PPD for that WU averaged over 3 WU's. The frame times are around 9:15 and that is while running 2x GTX560 TI's......
This is on an i7 950 @4G....
Actually I'd like a steady diet of these WU's
I'll tell you what's one of those annoying F@H things.
The cost and not knowing when to stop.
So we all know by now that I picked up a cheap 771 Dual Xeon workstation (HP XW6400 to be exact).
2x2ghz Dual core and I put my GTX 460 in there.
Well, I couldn't leave well enough alone. Winging it's way to me are two Xeon 5160s which run at 3ghz.
Nice. Are those xeons quad cores?
only problem is I don't seem to be getting points for doing them
i completed one at 4AM this mornning and i still don't have any points for it :/
I'd be double checking my config file....
looked in them and everything looks fine to me
says it is submitting to my username and our team
looked in the psummary and the projects text file and neither are showing the units :/
tried updating the projects list twice and it still doesn't show
Why is it always when you babysit the FAH , nothing goes wrong,
ones you sleep, BOOM re-boot *(stupid windows update that I forgot) or whatever
, lost 2 updates.. so a lot of hours of Folding
That happened to me and I changed the settings to only notify me when there are new updates. It's annoying though as I lost a lot of points.
Finally have my i7 930 doing some decent PPD. It was averaging around 8000 PPD at 4GHz. I set both of my GPU console clients to use -advmethods. The top card was hitting 96C though, so I took off -advmethods on that card. With only one card doing -advmethods, my CPU PPD is now at around 15k, almost double!
