Those little annoying F@H things ..
DAMN YOU 6701.... DAMN YOU
EDIT: 10 mins after I made this post I finished my current WU and guess what my next one is???? 6701
You get lower PPD with 6701 and they take much longer to do, so if like me you fold on the PC you use it's a nightmare because they can take up to 18hrs, they do for me anyway
I've found that, I'm using my laptop to fold at the moment as I was having a few issues with the pc. It seems to be taking forever on the laptop
You could be looking at over a day for a 6701 on a laptop and if you use it, even longer.
I'm trying not to use the laptop too much, just for things like MSN because it's easier than sitting in the dining room at the pc when i can be comfy on my sofa with the laptop l
I've got just over a day ish for it to run
arrrrgh! this p***es me of
[22:00:48] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[22:00:48] - Attempt #17 to get work failed, and no other work to do.
Waiting before retry.
i may have just figured out the repetitive problem i have been having...
make sure that while initiating a WU (at client launch), no other memory hungry apps are running!!!!
IE: do not have any browsers open (especially firefox)
  • FAH GPU Tracker needs un-allocated reported memory to be TRUE.
  • it was reporting 4095MB to server (out of 4GB), when firefox was running and using ~1GB
  • the server was sending packets too large to be accommodated and failing
just a little heads up
lol - according to the stats - it'll be never
bwah hahahaha
i haven't even got my new rig yet
i am not using any GPUs (as they slow my SMP down)
and i haven't folded the PS3 for a few weeks
aim for someone else, that you will overtake - lol
EDIT: i do like your spirit though
Be warned all PG has just released the successor to the despised 670X WU's, and this variant is even worse with more heat and poorer points.
Coming soon to your local F@H Work folder!!!!!
