Those little annoying F@H things ..
Back up and running now. CPU sitting at 70C now, GPU 1 at ~65ish and GPU 2 at 73C. Much better.
Glad your temps have gone down
On a different note my GPU 0 has frozen in GPU tracker at 8% how do I restart it? I have stopped all clients and restarted them a number of times but it stays the same. I deleted the WU but it still shows the old one, and resumes it any ideas?
Happened to me. Restarting the client didn't work, however rebooting the pc did.
Thats basically what happened, deleted any thing to do with GPU and when I switched back on this morning it grabbed a new one
My main rig is down again. It seems it won't run stable on anything above 2.2GHz now. Only had about an hour to mess with it. The PC kept locking up at the desktop and I was getting graphical glitches. Thought it was one of my 470's acting up. I cleaned/reinstalled drivers and everything was working again...or so I thought.
My board automatically clocked the CPU down so it would be stable again. I didn't notice right away, but when I did I tried clocking it to around 3.4GHz and it won't even load the desktop, no matter the volts. This CPU used to be bench stable at 4.4GHz no problem, now I can't even get to the desktop at stock settings (2.8GHz). For now it's off, there goes ~30-40k PPD. I'll have another go at finding out the problem sometime this week.
Eek, and I thought thet fact that I am away as of tonight until friday was bad, I am only losing appx 4-5 k ppd (which is all of my points).
Doesn't sound too good blah
Hopefully I'm just missing something. I was pretty hungover when I was troubleshooting
. I was really hoping this system would last me until Ivy Bridge or Bulldozer arrives. What's the safe max temp for an i7? Do you think 99C killed it? Strange that it worked fine again for a few days before it decided to act up.
Does it post overclocked and just fail after loading Win?
It posts fine. Windows will either go to a black screen when I sign in, or will lock up on the screen that says "Welcome" before I actually hit the desktop. Lower the clocks and everything is fine. I've been wanting to do a reinstall anyway, so maybe I'll give that a go.
How is the ram behaving (stock and overclocked) if you run a memtest x86+ bootcd?
I'll give that a shot when I can get back to troubleshooting. I've always run the memory at 1600 (7-8-7-24) 1.65v. That's stock for the memory.
I have a few PCs I need to fix on the side, so my stuff will have to wait. Hopefully I can get it all done tonight.
hmm,this should have been in the bragging thread.Have my 2nd fermi-card folding.Its a gigabyte 470 soc.Fine piece of hardware,running stock-speed 700@1400@837, and the windforce-cooler is in-audible at 65% temps 62c,very niece indeed.Here comes the annoying thing,if i try to push further than stockspeed it stops folding,due to unstable machine
So i have to use stock-clocks for now.
But 14.2k ppd is always welcome
Happy folding
I woke up this morning to a rebooted PC only to also find an alarm clock flashing 12:00 lol I was soo hoping to rid my 930 of the 2684 it's crunching out
Same here this morning al tho it was just my main rig that rebooted , guess it didn't like 4500Mhz
did run a few hours F@H load but i forgot to clock it down a bit as i was still testing the voltage on 4500Mhz.. a well tries again
Ieuk (EDIT) i see it rebooted pretty fast after i turned down my monitor so i lost a whole night methinks...
/checks logs YES almost after i went to bed it rebooted...
