The good GPU3 WU are showing up here!!Hope everyone is getting them....![]()
Man i am [--|-] that close of going to freak out with this POS software..
hanging clients and not a single good WU...
Others (see above) get better WU's i just don't see them at all (yes the 67xx WU's ),
how Charlie keeps getting BIGadv WU's (keep it up tho, of course i'd rather see you get them then not at all) is a mystery to me ?!
I need a break or something or some FREAKING luck for ones !
I'm still getting 6701's as well! I think we need to do some kind of wicked voodoo to get our folding luck up. Maybe sacrifice a few sheep?
You aren't the only one getting 670x's, I think all my non -bigadv machines are on them.
With this current run of crap WU's my PPD has dropped close to 40K per day![]()
Ray, have you tried using GPU Tracker to control everything? I find it to be totally trouble free.
You'll probably find the allocation is based on return rate or something similar.
My advice for you would to go back to stock on both gfx and cpu and run advmethods/a3 whilst you overclock. Overclock 100MHz at a time ( I usually Fold for 2 days before increasing the overclock) on the cpu and 50MHz on the gpu. CPU, then GFX. Break the CPU down into Core speed and BCLK so you know it's not the BCLK causing the CPU to be unstable.
Take it slow and rule out each and every problem one at a time. There HAS to be a cause to all your hardware issues.
That´s a good idea, i am going to do so.. thank you for the heads up matey![]()
can´t get any worse then it is now...
Guys if you don't get the 9xx WU's its because you need the -advmethods flag again![]()
o man stanford ...
Got a link, Mr Ray?
o man stanford ...
wonder y i aint gettin themdeleted work folders and all that think its time to try that gpu tracker out![]()
Did you know that makes it really easy to run SMP?![]()
