Dicehunter
Resident Newb
I'm up for anything, Strikes, Raids, Nighfalls, Forges, Menagerie, Helping with quests, Just name it ^_^
That sort of performance drop is what is what would stop me from buying AMD for my next cpu, for my gaming pc because it's mainly Destiny 2 and The Division 2 that I play on my pc.
I wonder though if that performance drop is in part way down to the issues they had with the 3000 series cpu's when they launched, is it like that in other games or is D2 an outlier?
I wonder why the difference in GPU usage. That would explain the fps jump. Your Intel system is at ~90% GPU whereas the AMD system is at ~50%.
Ah, missed that part. Are you playing at 1080P to run at a higher refresh rate? All the early benches showed 1080P was where Intel pulled ahead. Seems so backwards though running that resolution.
Well they are still having issues with Ryzen 3000. I bet if you used a Zen 1 CPU you would have more frames.
I actually had way less when I was on my 2700X, Nothing bad or unplayable but not anywhere near the performance I should've had.
I'll be moving on from the 9900K next year anyway when AMD release the 4000 series.
just assumed they never got round to fixing the issues with destiny 2.
Seems that game just prefers intel, clearly.
