The Incredibly Thirsty Hulk
Looks amazing dude ;)
Thanks mate :)
Just a little update for you guys:
Ordered the D5 pump top upgrade kit 250 (black POM version) because I'm planning to move to a bigger case next co-op term so that I can SLI. Reason for the case switch would be so that I can get more radiator capacity since I'm pretty sure my current rad setup wouldn't do so well with another card added to it.
I also ordered myself some mayhem's pastel mint green concentrate to change things up a little, since the dye solution I had didn't look too nice with the whole tubing discolouring :\
Anyway, here are a few pictures of my rig at the moment. Expect some more updates in the new year! :D
Had some acrylic leftover from the bitfenix shinobi window mod, so I cut out a piece to cover the gap under the optical bay and hide some cabling. Also added carbon fiber wrap to this piece of acrylic and the top of the power supply to give a cleaner look. And no, those are not cold cathodes, it's an LED stick. No flames please! :P
Personally think the 250 res upgrade makes the whole pump setup a lot cleaner. Glad I went with this option.
And of course, can't forget the shot with the water block...
I promise to eventually invest in a proper camera...these phone pictures don't do it enough justice. The coolant colour in these pictures don't really match the colour you see in person. Try to picture the green from Aero mint bars (not sure if this helps).
So, what do you guys think? and just to get a rough idea, do you guys like the pastel coolant or the clear green coolant better?
Thanks!
Ryan
any thoughts on the advanced LRT tubing that's going to be coming out? sounds fairly promising from what i've been reading...
My Primoflex Pro has clouded up horribly. According to Primochill's website, it's not a plasticizer issue. Either way, they recognize the issue and I contacted them and within 6 hours they sent me 10 ft of their Primoflex Advanced. Apparently it fixes all of their previous issues, and that's been validated by quite a few people on OCN.
Nice rig Mate!
This is lovely xD
Thanks guys! :)
How do you find the cathodes? Out of the 5 or so sets I've had pretty much all have blown up.
Looks good though :p
Thanks mate. Those are LED sunlight sticks, so they won't blow up like your cathodes. I used to have cathodes too, but all the forum members flamed me for having them :P
I didn't know you could contact them directly and receive a batch :O I've been waiting for retailers to get them in this whole time...I'll look into that. Thanks! :)
