Sorted Charts
maniac
I was reading the group radiator review and decided to make a point on something that's been bothering me for some time now. The bar charts of the main reviews (atleast) should be sorted low-high or high-low, doesn't really make a difference which but it would be super helpful if they were, personally I find it easier to follow if they were sorted as you can compare by seeing which cooler/component is at the topmost or at the bottom instead of having to go over each one and reading the temperature.
Regard,
maniac
