grandpatzer
I'm soon going to decouple my pumps with shoggy sandwich to decrease vibration noise.
However my undersanding is if I use the built in glue then the shoggy will permanently be stuck to the case, as I may want to eventually put pump elsewhere or other PC case I was considering putting something below shoggy so I can easily remove it.
I was considering this: Pump above Shoggy, glue something below shoggy so it is not attached permanently to case?
Maybe put a sponge below shoggy to even further eliminate noise, or maybe have soome plate below it?
