SKEEPER - custom business card.
There will not be a block on the GPU :).
The card comes with factory design - it is beautiful.
Going out of it is getting an identity - I do not want to do it. The purpose of the project is the events and the book, so the temperature and noise are not interested in me.
And besides, the factory appearance let him defend himself because he has something. :)
The CPU will be a Phobya UC2 block.
Today I checked what shines and what does not.
When it comes to MOBO, besides the lights and the code display, the only decorative light is the red strap (to swallow).
The only light effect of my Goddess is the subtle highlight of the logos and card model ... in addition to white - perfect!
Headgear for EVGA that it has not made of these products that celebrate the RGB luminosity, shimmering Christmas trees - I appreciate it!
Yeah, the block is not ugly.
Today I made the rear fixing of the card.
Ahh, i love this surface after milling :)
Oxidized aluminum rods - these will be supports.
Mounted.
Yes it is ... looks.
Thank you :)
At the back of the card are three holes under the M3 screw.
One used for the third stand.
The card is now suspended in the air and does not crush the riser.
Thank you :)
I do wonder what the actual purpose of those 3 screw holes was for. After all I see it even on my 780 cards. I guess retention brackets or support in some way.
Mysterious holes - are, so I used them :).
On one of the coolers I have to put one tube underneath the CPU block.
It is so tight that without modifications it will not work.
The solution would be to drill a new fillport hole in the right place, but there are holes in the factory, so there is no room for another hole.
I had to make an angle fillport of the right height and with the ability to rotate (I have not done so yet).
Almost pressing - the distance between the fillport and the coupler in the radiator is less than a millimeter.
... but somehow succeeded.
I also start earning tubes - no one will be bent, because I hate to do it, and under the deck I will combine all the snakes.
Covert backwards.
Done.
At the suggestion of my friend Patrick, today I also made Custom screws on the CPU block.
Originals look like this.
Custom screws look like this.
We lay down - below the deck some cables (I do not like them) and several connections of the liquid cooling system (5 fillports, 2 coolers and pump).
Thx.
Continued.
To Phobya benchtable will eventually target EVGA memory, but still not reach me, so courtesy of GOODRAM will temporarily pre-release Iridium. (Premieres tomorrow :))
