No, these are not heat exchangers, these are passive coolers Alphacool Cape Cora.
These are not popular, they are forgotten - I decided to use them, because the interesting complement the project.
For coolers Phobya HPC will be mounted fans Alphacool NB-ELOOP:
Why I chose LED strip, which is not RGB and is in addition unprotected IP - primarily suitable light color, smaller and more densely positioned LED (very bright), the width of 8mm.
RGB strip, at least those that I have seen, do not give such a light color which interested me.
White light there is some pink.
The lack of any protective coating IP gave me the opportunity to actually bend the tape as a sheet of paper, thus nicely put together in the corners without cutting, soldering, or the use of angled connectors.
If I instead coolers HPC applied classic black, the backlight of them would not make much sense.
While illuminate as bright aluminum fins in the radiator HPC, the effect is (IMO) very nice.
Fixing radiators Cape Coral.
The factory in the set there are any clips for fastening with self-tapping screws, but unfortunately I do not use them because they are ugly and would be on view.
The radiator has only one hole 3 mm.
The idea was to make a longitudinal channel, through which will be able to adjust the position of the radiator.
So that it can adjust the position of the cooler, the agent must have hit the insert with a threaded bore, M3 is shaped such that when the tightening does not rotate in the center.
Inserts made of rod fi12 (this had on hand ).
These two pieces will cut across and we will have 4 pads (2 on the radiator).
I used to cut the cutter blade with a thickness of 0.4 mm
We cut.
Drill holes for the tap.
... And quickly inserts ready.
In this place they will be loaded before installation.
Beloved, informative write that both projects will be powered by a very, very good power.
Benchtable will be armed with the Prime Titanium Seasonic 650W, and be quiet Dark Base Pro 900 will get a new, sensational fall out in the test unit EVGA (information soon).
Forgive me, please, now I understand what you mean.
But I have a few words from each other - cooler is of course a kind of heat exchanger (by definition), but speaking of the heat exchanger had in mind such a device - CLICK.
In them heat exchange (not putting as in the case of the cooler).
My Phobya and your Water is Cool coolers HPC (High Performance Computing).
They are specific, transferred from the industry. I chose them for this, because they are very nice, not very popular and their bright aluminum fins fit into my project.
Almost 99% of projects are coolers black and is in addition covered fans. You can only see their sides.
In my project will be different - shows off aluminum fins
So yes, everything is correct - the definition of the cooler is a heat exchanger. Heat exchangers are several types, hence our misunderstanding.
Let's get back to work.
Somewhere I saw and decided to do it myself and try for carrying out a tube cables through the braid.
I have to admit that the invention is simple and very easy to work. They not hook the pins of the braid, so you do not inhale it, and the imposition of braided cable is much faster - I recommend.
This photo pay homage to those who know their stuff, have patience and do it efficiently and aesthetically.
Cat ...... intriguing being in no way helped, just the opposite.
What does it mean to have a good tool ....
In some photos, you can see the company logo BRENZER Poland I am not obliged to insert this logo, but I want to, because the initial collaboration grew into a perfect friendship with the people who work there.
BRENZER is a distributor of tools such brands as Noris Reime (taps) and Komet Group (cutters).
These are industrial tools for incredible strength and precision. You can not buy in a regular store.
Noris Reime nicely brings out chips, while the other, which I have (well known brands), load the chip inside the dies and the long tapping clog it.
As I have already mentioned it, it can show you (as a curiosity) some interesting tools, and some photos of the event, on which I have been with the company.
You see also some of my other work and the reservoir, which will be mounted in the Dark Base Pro 900.
Event in Mikołów (city in Poland) was organized in the school and had to show young people live, what is modding, as they look modding computers.
There were also organized workshops, which were built from scratch computer Step by Step.
You could also listen to lectures on photography modding (yes, it exists, my dears).
The whole thing was to bring everyone (not just those who are familiar with and like) how our passion and hobby.
I showed the Company Brenzer and together we could show young people not only ready-made reservoirs and other additives for liquid cooling, but you could also see by what tools they are created.
Several reservoirs in the showcase.
The reservoir of the left side is mounted in the Dark Base Pro 900.
My custom plexiglass TOP - water block RAM
A few more pictures of the plexiglass TOP and video.
Reservoir for the project is already finished.
A few technical data.
- The diameter of the tube 60mm
- Diameter of the left ventricle and right 70mm
- Length 295mm
