Go scsi man
i havent looked back ever since...
your U320 scsi drives dont even reach 160mb/sec man so nothing to worry about...
U320 means nothing...Your drive will say reach 80mb/sec...if you have two of them then youre looking at say 160mb/sec if they are in the same channel..which means an u160 channel is maxxed...BUT
youre running a 32bit pci card so its a lot lower...and these speeds are by 15K drives...
i am using a latest 15K rpm Maxtor as boot...and a 10K Maxtor for my mp3s...200gb sata for storage...
Rig is very responsive... i am never looking back
I upgraded my 29160N adaptec adapter for an 39160
which has 2 u160 channels...still i wont bother installing each hdd in a seperate channel..no point...i got the controller used for £45
so go in e bay and look for adapters
get an adaptec one..29160-29160N-19160-39160 will all do used...make sure you get an LVD cable with it cos they are expensive...
dont get an u320 card cos its a waste of money for now and i have seen the PCI E versions only tbh so far...
how many drives are we looking for?
