AlienALX
Well-known member
Last night I decided to fit the sound deadening material onto the DVDROM drive. I had a look over it, and realised pretty quickly I could not deaden the top. If I did then it would not have gone back into the case. So, instead I removed the drive, then removed the face plate from the HDD bay I fitted and instead I completely covered the bottom of the DVD drive. I also deadened the sides of the CD bay.
And the other side obs, where the pieces were bigger because the mech to remove the drives is not there. And it did the trick ! all you can hear now is a gentle whoosh as the drive spins up with no rattling or buzzing. Awesome
The top and right side are now back in place.
So as soon as I feel better I will finish the two cover panels
