Raid 0 on Asrock - problems
Wab
OK I have installed raid on on asrock but now I cant see my old drives - raid 0 is on two WD250GB SATA2, old drives are are on IDE 120 and 80 GB Seagate's.
First - as of now I'm running on old drives again array broken and have wiped drives clean.
2) when I set up the array it was supposed to be sata2 but I'm pretty sure it ran in sata1 only ( using floppy to install drives sata 2 ones keep failing)
So how do I get SATA2 working in raid 0 and also be able to see my old drives, I saw some one has said on another board that when installing sata2 you do not push F6 but put in floppy just as Windows starts to boot? is this true?.
ANY HELP WOULD BE APPRECIATED
Shit mate I'll get back to you on this once I get my new case and start working on getting everything installed as I'll have to RAID up my new SATA2 Hitachi's.... But that won't be any time soon enough to get you any immediate support.
I know there are a few people here with RAID SATA2 setups, they should be able to help.
