Y Youngie1337 New member Dec 10, 2008 #22 name='Ghosthud1' said: around 30 inc posting but ill probs sell next week or soo Click to expand... Ahh never mind then , still got lots to buy for other people. Cheers for the offer if it hasn't gone by the time I'm ABLE to purchase one .
N noobieocer New member Dec 20, 2008 #23 well scince its temp, i recommend a cheap arctic cooling freezer 7 pro, its only £15 and does great for now. i;m sure you reach 3.6Ghz with it
L Luigi New member Dec 21, 2008 #24 name='noobieocer' said: well scince its temp, i recommend a cheap arctic cooling freezer 7 pro, its only £15 and does great for now. i;m sure you reach 3.6Ghz with it Click to expand... Nope, Mine got to around 3 on the freezer 7
N noobieocer New member Dec 21, 2008 #25 name='teknokid' said: Nope, Mine got to around 3 on the freezer 7 Click to expand... well you can always stick with it until new years. i mean why do you MUST have 3.6ghz now? you can spend like £40 on a high end air cooler and then buy water cooling after new year or just stick with it and buy better water cooling system later on.
T TomaszPawel New member Dec 22, 2008 #26 Hi! I have Zerotherm Nirvana Nv-120 Premium. So it is very good cooling, but it it very sensitiive to ambient temp. E.G. In winter q6600@3312 have 60-75C but on summer q6600@2800 have the same temps....
H Hatman New member Dec 24, 2008 #27 Hi. What voltages have you been using? I think I am unfortunate enough to have been blessed with a crappy chip as my Q6600 wc'd won't stay stable at 3.6ghz with 1.47volts : (
L Luigi New member Dec 25, 2008 #28 name='Hatman' said: Hi. What voltages have you been using? I think I am unfortunate enough to have been blessed with a crappy chip as my Q6600 wc'd won't stay stable at 3.6ghz with 1.47volts : ( Click to expand... Mine is on 1.45v IIRC... I had to Up my NB and PLL volts to get it stable though...
H Hatman New member Dec 25, 2008 #29 Well I left those on auto assuming that the motherboard would simply give it too much anyways so i think imma probs try them on higher.. Merry xmas all from hatman (trying to fix computer to play new games.. *sigh*)
