Really nice build and log to go with it, im loving my switch and you sure seem to have made yours into a beast!![]()
Looking awesome! Hope I picked all the cables you neededI was going to have them send the 1-1 SATA power cables, but we were out of stock so I did the molex to sata.![]()
The HTF4 has the same spacing as your rad, sorry about that, we will keep this in mind for the future. For the CES build I had to cut slits to align the rad. Luckily because of the top plastic I did the push pull and you couldn't even tell.![]()
Lookin' very snazzy indeed.I think your choice of bay res and fan controller compliment the black on the front - "Switch Blade"?![]()
looks amazing, love the pastel coolantyou should call it ^ and light switch for the little one XD![]()
build is looking awesome mate, its going to be even better with the pastel fluid, can't wait to see it![]()
Sweet mother of god.... that looks goooooood!![]()
Thanks bro
ok was a tad bored today (home sick with flu) and after sleeping for what felt like an eternity I had a lil energy to expel. Some may of been following the convo with magic8ball and myself on xRavenx's op on the switch 810 from CES. Been toying with the ideal of making my fan controller work with the hot swap bay. Now had I not been sick and had a few more items at my immediate disposal it can be done with alot of fitting and such. The bay tray included with the 810 has the hdd elevated so the screws that hold the hdd in dont scrape the floor of the 5.25 enclosure. So what i did was cut my NZXT Sentry's bay down in half (its like an optical drive in length) and got it to fit back in the upper 5.25 bay after doing a little surgery on the rails for it. The upper most 5.25 bay's sides are removable and have to be to put a 360 or 420mm rad up top. But with a 360mm rad you can put them back in easily. With a 420mm rad the slide supports for the optical drive have to be cut off. This is what I accomplished today. Sorry camera is dead atm and no pics. But now I have the hot swap bay back and usable. Now to answer a question as to if a optical drive is usable in the swap bay........ the answer is no the power and data plugs are about 3mm different in right to left orientation.
Thanks still waiting on the pastel fluid been in contact with Mick and were thinking it may be held up at customs for some reason. I mean come on its just liquidBut he needs to check with his shipping guy who's out on bereavement til Monday so I should know more next week.![]()
thanks matebut she aint done yet![]()
more parts arrived today a HUGE THANKS to Irene and the NZXT Team for the sponsorship of my 2 buildsgot 2 sets of braided extensions and another 2m blue leds strip for the builds![]()
yes use a 360mm rad instead the extra 20mm per fan wont give ya any extra cooling (well depending on what your cooling) if you dont have the tools to mod it stick with what just bolts in.
